offset question
Old Oct 4, 2009 | 08:30 PM
Silencer_F22's Avatar
Default offset question
i am looking to buy some Rota DPT the specs are as followed
(5x100/114.3/e42/73)
Wheel Diameter (Inches) - 17"
Wheel Width (Inches) - 9"
PCD Bolt Pattern - 5x100 & 5x114 (dual drill)
Offset - 42mm
Hub Bore - 73mm
will they fit on a stock s2000 without having to do any modifying
Old Oct 4, 2009 | 08:59 PM
PsykotiK's Avatar
no.. roll, small flare, relocate the rear tabs and possibly trimming the bumper a little.. also depends on the tires sizes you are going to run
Old Oct 5, 2009 | 09:09 AM
Tripleblackap1's Avatar
+42 is a little to agressive for stock fenders.
Old Oct 5, 2009 | 09:40 AM
BSeriouS's Avatar
You will have to roll your fender, relocate your rear bumper tab, and cut the rear bumper. Of course this is dependent on how low you plan on going
Old Oct 5, 2009 | 06:33 PM
what tire size would u recommend i was thinking of just using the factory tire specs? also dose any1 know a good shop in the central vally or nearby that can get these wheels to fit right?
Old Oct 5, 2009 | 06:34 PM
i dont plan t drop the car anytime soon but i plan to drop it like "1 maybe "1.5
Old Oct 6, 2009 | 12:39 AM
BVE's Avatar
BVE
I have 8.5" with et42 and I needed a roll, bumper tab relocation and bumper cut. No flare needed. I'm running 245 rear tyres.
the half inch of wider wheel will not make enough of a difference to rub with -2 degrees camber (UK alignment specs).
At 1/1.5 inch drop, there should be no problem, I think I'm at 2/2.5" somewhere.
Old Oct 6, 2009 | 05:22 PM
BVE do you have any pcis of your setup?
Old Oct 6, 2009 | 11:47 PM
BVE's Avatar
BVE
no decent ones... need to do a decent photoshoot without oversaturating the pics
This one before camber was dialed in, I just turned the rods to max negative camber in the rear (the toe links, so massive toe-out as well)
Old Oct 7, 2009 | 07:30 PM
viets2000's Avatar
Nice EDMness
nichigo
May 31, 2009 10:55 PM
oranje
Dec 17, 2008 05:01 PM
miamiE46
Sep 26, 2008 11:15 AM
upsdoc
Aug 23, 2008 07:20 PM
-KEY!S2K-
Dec 15, 2006 05:15 PM
