Offsets
Old 09-25-2007, 04:12 PM
cannonball's Avatar
Default Offsets
Hey guys, sorry to keep beating this subject into the ground but I am totally green to sports car and wheels and offsets.
So I think have read everything or almost everything having to do with wheel sizes and offsets ect. that have been posted. I've looked at wheels and offsets long enough, that I now haven't a clue as to what will work and will not work. I just can't visualize the offset/rim on the car.
1. I understand the whole stagger concept, ie. performance / stability / handling...what I want to know is: Can I run a staggered wheel (example: 16x7 and 16x8) and have the same offset on ea. rim? (something like a 45 or 48)
2. If not does the higher offset go to the rear and the lower offset to the front?
(ex. something like a 16x8 et.48 rear and 16x7 et. 40,42, or 45 front or do these #'s need to switched so the rear is smaller and the front is higher)
If so why?
Any info will greatly be appreciated!!
Thanks
C-ball
Old 09-26-2007, 03:28 AM
cannonball's Avatar
Bump
Old 09-26-2007, 06:46 AM
Sinji's Avatar
1: yes you can have the same offsets on staggered wheels
2: most usually run lower offset fronts to run bigger brake kits.
Old 09-26-2007, 12:24 PM
Project22a's Avatar
http://www.tirerack.com/wheels/tech/...jsp?techid=101
Old 09-27-2007, 05:35 PM
Jeffrey Song's Avatar
Typically, lower offsets are used to get the wheels closer to the fender.
Normally, cars run the same offset in the F and R even if they are running staggered wheels, but it's not THAT important.
Too low of an offset will rub against your brakes/calipers but will give you the maximum lip so a lot of people buy the lowest pad, lowest offset possible and throw a spacer in there to clear their brakes.
clarkster009
08-22-2010 03:52 PM
Shipley
09-08-2005 12:23 PM
CDUCTV
09-18-2003 09:46 AM
alexf20c
01-14-2003 07:41 AM
samlee888.com
09-04-2002 03:43 AM
Quick Reply: Offsets
