is it possible to adjust the ride height?
Old Nov 3, 2002 | 09:27 AM
lostsol's Avatar
Default is it possible to adjust the ride height?
the driver side of my car seems to be a bit lower than the right side. I measured where the 4 jacking points are. Is this normal or is there something I can adjust to even it out? My car has stock supsension and it's a 2001.
Old Nov 3, 2002 | 11:06 AM
Schatten's Avatar
you might want to inquire with the under the hood forum.
if all tire pressures are the same - 32-36#'s each, not really anything you can do at all.
how much is 'a bit', and was the ground level where you measured? if not, the suspension will tweak to a corner or side.
might want to check for spring spacers in the springs - even if you've had the car for a while. sometimes dealerships forget to remove them upon delivery.
killyougood
Feb 26, 2007 01:49 PM
Porsche951
Apr 26, 2003 05:19 PM
StknCaS2k
Feb 16, 2003 02:28 PM
be17jamln
Dec 20, 2002 03:34 PM
enguyen7292
Nov 8, 2001 01:57 PM
