Possibly good match
Old Sep 9, 2010 | 08:48 AM
  #131
TubeDriver's Avatar
Originally Posted by scareyourpassenger,Sep 9 2010, 09:23 AM
I forgot to bring a scale to discount tire
I weighed them before and they were 17.x lbs.
That is what we need to figure out, is the "X" a .1 or a .9 (or somewhere in between). My digital scale says 18.4 (assuming it is accurate and that the nitto tire is actually exactly 26lbs).
Old Sep 9, 2010 | 08:54 AM
  #132
scareyourpassenger's Avatar
It is above 17.5 and I think closer to a 17.7.
Old Sep 9, 2010 | 05:40 PM
  #133
nickp's Avatar
when i weighted mine on our ups scale at work mine weighed 17.7 and on a digital scale was 17.9
Old Sep 10, 2010 | 07:34 PM
  #134
phunky.buddha's Avatar
You have to take into account the wild error of digital scales produced for the home consumer... anything around a half pound is probably as close as you're going to get.
FINALLY got mine on. Apologies for the huge post, but not too many people are replying to the thread anyway...
Sorry, crappy iSuck pics. No good camera right now.
Stock suspension
Stock alignment
Comptech front sway set at 4/5
17x9 +63 all around
255/40-17 all around
Stock setup:
New setup:
Weight of new wheel and tire together:
Front fitment:
Rear fitment:
255/40-17 Hankook RS-3 (right) vs 225/50-16 Fuzion ZRi (left)
255/40-17 Hankook RS-3 (right) vs 245/40-16 Hankook RS-2 (left)
245/45-16 Hankook RS-2 (left) vs 225/50-16 Fuzion ZRi (right)
Weight of stock front 16x6.5 +55 wheel and worn 225/50-16 Fuzion ZRi (40.6 lbs):
Weight of stock rear 16x7.5 +65 wheel and worn 245/45-16 Hankook RS-3 (40.4 lbs):
Empirical "evidence" of grip gain... this was obtained through my Apex'i RSM with the accelerometer (G sensor) mounted on the firewall. It's pretty accurate- more so in my opinion than the ones that just plug into your cigarette lighter and wobble around. The highlighted numbers are the peak measurements since the last reset, large number is current state (taken on sloped driveways, parking lots). Top line is forward/reverse, bottom line is left/right. The only one measurement that I'm putting any weight into is the top line for braking power. I measured by stomping the brake as hard as possible from 80mph to 20mph.
Stock setup with Fuzion ZRi in front and Hankook RS-2 in rear, playing on the way to work Thursday:
Immediately after the RS-3s were installed (not scrubbed in at all yet) and on the way to work today:
0.14G gain!
After work today, playing with a racer buddy:
No real impressions yet... even though each corner is about 5 pounds heavier, the car feels great. There is a more squishy feeling since the tread is new and at full depth, but the grip is GOOD. The rubber grabs gravel just like my old S-03s did on the Civic, which was a little worrying when I pulled out of the driveway on the way to work today. The sidewalls are pretty compliant, and seem to respond quickly just playing around going from lane to lane at speed.
Need more time to really tell about the tires, but I think I'm going to like them a lot.
Oh, slight rubbing at full lock so far- sounds like rubber on metal, not metal on metal like some others have reported. Will investigate more later, but I think I'll run with 5mm spacers in front after a drop and alignment and probably 10mm spacers in the back, so it won't really be a factor for me.
Old Sep 11, 2010 | 03:32 PM
  #135
DSKC's Avatar
My set is being refinished before installing.
ETA: sometime next weekend, pictures to come...
Old Sep 12, 2010 | 03:05 PM
  #136
DSKC's Avatar
finally installed
Old Sep 12, 2010 | 04:17 PM
  #137
EOE's Avatar
EOE
More pics and angles please?
Old Sep 12, 2010 | 04:37 PM
  #138
nickp's Avatar
Originally Posted by DSKC,Sep 12 2010, 06:05 PM
finally installed
howd you remove the gun metal?
looks good on white
Old Sep 12, 2010 | 04:40 PM
  #139
nickp's Avatar
better angles?
  #140
yonson's Avatar
[QUOTE=DSKC,Sep 12 2010, 03:05 PM] finally installed
