pros and cons of going non staggard
Old Sep 1, 2007 | 02:51 PM
chillout18's Avatar
Default pros and cons of going non staggard
Since there arent many choices for staggard setups I was wondering what if I go non staggard. What offsets would I should look into for 17 and 18" wheels. also what are the pros and cons of going non staggared,
thanks
Mike
Old Sep 1, 2007 | 10:28 PM
iam7head's Avatar
there's generally two type of people running non-staggered
one type is moron that looks for some cheap wheels
another type if track junkie that needs the extra braking and turn in. (9 inch +)
if you are doing non-staggered because you can use cheap wheel, you are doing it for the wrong reason
Old Sep 2, 2007 | 05:48 AM
chillout18's Avatar
well what am i loosing if I go non staggered?
Old Sep 2, 2007 | 08:36 AM
Project22a's Avatar
If you're gonna be running anything less than 245 all around, you'll be losing a significant amount of overall grip and handling.
If you're running a 245+ all the way around, your overall grip will be improved, however your car will have an oversteering tendency. Track junkies usually counter this with an upgraded front anti-sway bar.
Most people with staggered setups run a 17x9 +63 with 245 or 255.
Old Sep 2, 2007 | 09:50 AM
Luke530's Avatar
if you don't know what you're doing (at the track), or why you would run non-staggered sizing, then running non-staggered sizes is not for you. stick with a proper stagger.
Jibarito
Feb 10, 2015 04:02 AM
wowwitsgau
Jan 24, 2014 09:46 AM
razzele
Aug 4, 2009 11:22 AM
PapiChulo
Jun 14, 2009 07:52 PM
JustinMcC
Dec 13, 2005 02:15 PM
