Which rims for J's Racing BBK
Old Dec 28, 2009 | 06:21 AM
vtecmall's Avatar
Default Which rims for J's Racing BBK
Hi,
I've just bought a J's racing 6 pot BBK, I wanted to know the specifications of 17" to fit it.
Someone know a model and brand that fits this kit?.
Thanks a lot.
Old Dec 28, 2009 | 10:03 AM
vtecmall's Avatar
Any help would be very appreciated. Thanks in advanced
Old Dec 31, 2009 | 06:42 AM
vtecmall's Avatar
Nobody knows?, really? :-(
Old Dec 31, 2009 | 11:33 AM
rob.ok's Avatar
WedsSports TC105N 17x9 +49 fits and its the lowest offset wheel that will clear, but it only gives you about 1mm of clearance. If you go to a 17x9 +40 pretty much anything will clear as long as you take into consideration the spoke design.
-Rob
Old Jan 4, 2010 | 05:17 PM
vtecmall's Avatar
Thanks a lot Rob, but with this rims do I have to roll my fenders?. I'm going to lower a little bit my car woth KW V3 coilovers.
What do you mean with spoke design (sorry about my english )
R
Old Jan 4, 2010 | 05:45 PM
modMonkey's Avatar
If you can find Prodrives GC-07s, they clear at 17x8.5 +54. The standard s2000 offset for a 17x7.5 clears as well, but not by much. A small spacer would add some peace of mind.
I think GC-07J should clear as well (the GC-07 replacement). You can PM Tommy to confirm: https://www.s2ki.com/forums/index.php?showtopic=607887
Spoke design refers the the curvature of the spokes relative to the barrel of the wheel. Something like a CE-28 would not clear as well as the GC-07. Perhaps Rob can explain it better.
Old Jan 5, 2010 | 12:16 AM
vtecmall's Avatar
ModMonkey, thanks a lot for your answer.
So with these rims no fender rolling needed?.
Old Jan 5, 2010 | 01:49 AM
hahasti's Avatar
i believe J's car uses 17x9 +35 CE's and RE's..
CE's with that offset has lil bit of concave which i think is just enough to clear?
im jealous! nice brakes
if u go anything x9 +45 infront, u will need to roll and pull front fenders and rears just roll and relocate tabs.
good luck!
Old Jan 5, 2010 | 10:10 AM
vtecmall's Avatar
What do you think about advan RG2 in 17x7.5+45 fronts and 17x8.5+50 rears???
Thanks to all of you
Old Jan 5, 2010 | 11:30 AM
modMonkey's Avatar
If you run non-staggered (8.5 all around) and you have an aggressive camber setting, you can get away with 255s. I used to think rolling was a big deal, until you actually do it. I would roll the fronts depending on your camber.
