rubbing cure?
Old Jul 13, 2008 | 09:44 PM
Zomax's Avatar
wish that I could help but i'm so drunk. Sorry.
Old Jul 14, 2008 | 04:26 AM
03_AP1's Avatar
I can't fathom why one buys aftermarket rims and has no idea or concept of what offsets are.....
Old Jul 14, 2008 | 10:06 PM
lowandsmooth's Avatar
Def wouldnt recomend rolling the fenders on the S thats like rat rod thick steel fender days the S fenders are pretty thin kinda risky. I would just have bought the correct wheels or lift it up
Old Jul 15, 2008 | 08:38 PM
HondaS's Avatar
^^^^ people roll the fenders on the s all the time with no problems. i have mine done.
Ps your typing is horrible, it is almost illegible.
Old Jul 16, 2008 | 12:56 AM
SNu263's Avatar
His typing is fine, more of the spelling and punctuation that makes it almost illegible!
Anyway, it's off-topic. Just wanted to clear it up.
Old Jul 16, 2008 | 09:09 AM
jimbrowski00's Avatar
Originally Posted by Vanishing Point,Jul 13 2008, 05:18 PM
The tire size involved might be more of the problem than the wheel width, each brand of tires has varying spec's for their tires. Depending on the degree of 'rubbing" you might only need more neg camber for clearance.
I agree... tire size can have a big impact on rubbing... at least post your tire size if you don't know your offset.
Old Jul 16, 2008 | 12:18 PM
CaptainMike's Avatar
It would be helpful if you would post your offsets and tire sizes but not necessary. The cure for your rubbing ills is twofold.
You can increase your negative camber and/or roll your fenders. That is it, short of getting different wheels and tires.
Cheers,
Mike
Old Jul 22, 2008 | 09:25 PM
tcl's Avatar
tcl
Okay, this weekend I checked out the wheels and the situation more closely. The front wheels are 17 x 8055 +51. The rubbing is limited to one 3 inch spot on the inner fender (bordering the engine compartment) and a 2 inch spot on the top of the fender flare. There's a spot at the top where the fender lip pushes in towards the car a bit more to make room for one of those plastic screwless fasteners Honda uses to hold the car together. The fastener is gone and the plastic is rubbing away. I'm thinking a little glue and a push on that flange might solve my problem. But then what about the inner fender? That's just going to wear away the plastic until... what? What's on the other side? To fix that requires adding a wheel spacer, right? Which will make the wheel well issue worse which calls for fender flaring?
Old Jul 25, 2008 | 12:03 PM
HondaS's Avatar
what size tires
Jake Johnson
Nov 9, 2018 08:48 AM
hubertbateman
Feb 15, 2013 03:05 PM
drshottest718
Aug 2, 2012 09:03 AM
handyman1k
Jul 15, 2012 09:10 PM
markc24
Jun 11, 2009 06:31 AM
