Rubbing Question
Old Apr 30, 2003 | 04:13 AM
PAS2KNut's Avatar
Default Rubbing Question
I currently have my car dropped about 1.5" with Tanabe NF210 springs and am running 18" Volk LE37T's. I'm getting a little rub when hit a dip in the road. My rear tires are 255/35/18 and the offset in the rear is +50. Just had the alignment checked and I'm running -2.1 Left rear camber and -2.0 Right rear camber. Now not being an expert on this here is my question. If I were to reduce the drop to 1" or go back to my stock springs would this eliminate the little rubbing that is occurring.
Thanks for your help.
PAS2KNut
Old Apr 30, 2003 | 07:30 AM
Jim@tirerack's Avatar
Former Sponsor
I would think it would be less likely. You can also just roll the inside feder lip up and away from the tire to give a little more clearance and keep what you have. You can also use a slightly narrower 245/35R18 on the rear.
Jim
EOE
Feb 15, 2011 02:29 PM
Pelka
Jul 24, 2006 06:23 AM
JUN-JUNG
Sep 12, 2005 08:41 AM
TepEvan
Apr 7, 2004 10:25 AM
PLYRS 3
Mar 25, 2003 08:26 PM
