Running 205/50/16 on ap1
Old Apr 26, 2010 | 04:15 PM
ian02s2k's Avatar
Default Running 205/50/16 on ap1
I did search, but could not find my exact answer. I am in the market for tires, especially rears, and my neighbor has a set of 205/50/16 in his garage, brand new, and said if I wanted them, I could take them. I am aware that the stock front size is 205/55. Will this cause a problem with drivability/large gap in the wheel wells? Any info would be great.
Thanks
Ian
Old Apr 26, 2010 | 04:56 PM
G's Avatar
G
It will cause your front to sit slightly higher. It should reduce the gap, but that should not be a concern - it should be on how it handles. the taller sidewall will cause the front to have more flex and will result in a difffernt handeling feel.
The 60 series tire has a 3.16% larger diameter than the 55 series tire.
Old Apr 26, 2010 | 06:38 PM
ian02s2k's Avatar
I would actually be going from a 55 series (stock) to a 50 series. Not sure if you maybe missred that. But thanks for the input.
Old Apr 26, 2010 | 06:50 PM
Conedodger's Avatar
Specification----Sidewall----Diameter
--205/55-16-------4.4"---------4.9"
--205/50-16-------4.0"---------4.1"
The 50 series will be almost an inch shorter.
Old Apr 26, 2010 | 07:41 PM
ian02s2k's Avatar
Cool info, thanks. I suppose I don't want to loose an inch on the sidewall, that might look goofy. Thanks man.
Old Apr 27, 2010 | 05:13 AM
ZDan's Avatar
You only lose 0.05*205 = 10.25mm (less than half an inch) of sidewall, or 20.5mm (just over 3/4") in tire diameter.
What kind of tires (make and specefic model designation) are they? If they're good tires and appropriate for your wants/needs/usage (which are?), I might consider running two of them up front, but I'd probably get new 225/50-16s for the rear unless I was really hard up for $$$.
Old Apr 27, 2010 | 01:59 PM
ian02s2k's Avatar
^^They are BFG G-Force sports
b00stn
Apr 2, 2009 07:16 PM
tlee1234
Jan 14, 2009 05:54 PM
expomc
Feb 26, 2008 10:59 AM
stylinhonda
Feb 26, 2007 07:01 AM
YER-SLOW
Mar 12, 2006 05:58 PM
