Running 275 in the rear? Share your offset?
Old Apr 1, 2006 | 09:38 PM
C4SxM5's Avatar
whats the widest i can on 17x9 +63? Not going autocrossing or anything but like the rears to be wide as possible with no fender rolling.
Thansk
Old Apr 2, 2006 | 04:12 AM
hukares's Avatar
Since you wanted a real example:
Running 18" x 10.5" +73 offset in the rear with 285/30r18 tires. Fits great, had light rubbing on the fender lip (not rolled) with SO3 tires. Have no rubbing issues with FK-451 tires and the lips are still not rolled.
Old Apr 2, 2006 | 10:39 AM
wannabuy's Avatar
Sweet, thanks for all the responses. I have been looking for a reality check because the chart may say it will fit but real word doesn't always come out mathematically.
Thanks
-Chris
Old Apr 3, 2006 | 07:56 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Thansk
275/40/17 should be ok for the street.
Old Apr 3, 2006 | 08:19 AM
2QYK4U's Avatar
At stock ride height?
Old Apr 3, 2006 | 11:54 AM
Even with a 1" drop.
Old Apr 3, 2006 | 05:20 PM
WyattH's Avatar
That sidewall seems high... (Emil)
Old Apr 3, 2006 | 05:45 PM
C4SxM5's Avatar
im going to put on a used set of N555s 275 and see what happens. if it starts to rub, i will go with 265 and let everyone know.
thanks for the input
Old Apr 4, 2006 | 08:49 PM
MugenRioS2k1's Avatar
Originally Posted by jmargelo,Mar 31 2006, 03:21 PM
According to the stickied fitment guide, you should be fine with that setup:
For the rear:
8.0" wheel: +40 offset (225 or 235 tires)
8.5" wheel: +46 offset (235 or 245 tires)
9.0" wheel: +53 offset (235, 245, or 255 tires)
9.5" wheel: +59 offset (245, 255, or 265 tires)
10.0" wheel: +65 offset (265 or 275 tires)
10.5" wheel: +72 offset (275 or 285 tires)
I guess its not a "real life answer" though.
I would assume the fitment guided does not take into account a fender roll correct.
and using the 10+65 as a starting point in the calculator a 8+39 would only move the outer rim out .60mm and using a 255/35 section width 10.08 should work once the fender is rolled?
By the way the craziest think I have had on the car for a fitment check post fender roll and rear bumper modification (stock camber) 1.5 drop, bump stops unmodified was a 19x9.5+55 and had nor problems.
jimmy11
Dec 5, 2012 02:29 AM
XtbateU
Jan 29, 2012 09:25 PM
rmk232
Aug 14, 2011 07:55 PM
suzawadc2
Jun 23, 2011 12:25 PM
gre165-makis
Συμπεριφορά
Sep 13, 2010 10:22 PM
