sizes
Old Apr 4, 2002 | 08:29 AM
Cape Cod's Avatar
Default sizes
What is the 16x7 vs. 16x8? Also, the tires selected show different speed ratings for the front and rear????? The automatic selector picks 205's and 225's but shouldn't they be 225 and 245? I'm very confused as you can see.
Michelin Pilot Sport A/S
245/50WR16
2@ $202.00each
In Stock
Remove From Wish List
225/50YR16
2@ $192.00each
In Stock
Wheels
SSR Integral
See wheel on vehicle
16x7
2 @ $249.00 each
In Stock
Remove From Wishlist
SSR Integral
16x8
2 @ $249.00 each
In Stock
Old Apr 4, 2002 | 08:54 AM
xviper's Avatar
The 7 & 8 is in inches and this is the width of the wheel from "bead" to "bead". I run 16 x 7" all around for my winter tires (stock sizes). I'm not that worried about this since they are for winter, "non-aggressive" driving only. If you're going to drive this to the car's full capabilities like on a track, the front will be 1/2" wider than stock (OK) and the rears will be 1/2" narrower than stock (not sure about the consequences of this). I think only the rear SO2's are in reality bigger than they say so you should be aiming for 245's. But the fronts, as far as I know are accurate at 205. Also, offset is important too. Mine are +44mm and they stick out of the wheel wells about 1/2" more than stock. So this would increase the car's "track" by about an inch both front and rear and again, I don't know how bad this would be if you drive the car near its limits.
Old Apr 5, 2002 | 09:41 AM
Cape Cod's Avatar
Thanks. But why I'm confused is the Tirerack tire-finder-for-your-car deal comes back with the smaller size as the best fit. Guess I'll have to go the brick and mortar route and actually see for myself.
jetmagnum
Dec 29, 2010 10:06 AM
np2k1s2k
Mar 28, 2006 06:57 AM
00S2K01S4
Jun 10, 2005 04:00 PM
B18C5
Mar 11, 2005 05:14 PM
fuzy24
Oct 26, 2004 04:27 PM
