Spacers on stock wheels
Old Aug 21, 2009 | 06:57 PM
  #51
Swift GT's Avatar
Bumping this thread back up...
Will 15mm spacers all around work with 225/255 tires without rubbing? My car is going to be lowered on Bilstein PSS9's soon and although I have stock tires I'm wondering if I can run these and still go wider on the tires in the future. I don't want to be running crazy camber or anything but I don't plan on completely slamming it either.
Old Sep 7, 2009 | 10:34 AM
  #52
TJR's Avatar
TJR
I found this topic and I think is very helpful for those running OEM Wheels wanting to get some spacers
Spacer on AP2 Forum
Old Sep 8, 2009 | 08:28 AM
  #53
jdmfool's Avatar
j0nathanl3e what brand spacers did you buy?
Old Mar 4, 2010 | 11:41 AM
  #54
fishs2000's Avatar
Bringing this thread back to life.
Our wheel specs on AP2 v1's are 17x7.5 +55 and 17x8.5 +65 correct?
That being said, technically with a 15mm spacer up front and a 25mm spacer out back, this would equate to:
17x7.5 +40
17x8.5 +40
Am I wrong with this assumption?
I had 18x9 +43 out back with a 245 and did not rub at all lowered on Tein Stechs. Technically, at my height i should not rub with a 25mm spacer then right?
Old Mar 4, 2010 | 01:24 PM
  #55
ToEnvy's Avatar
I'm pretty sure you are correct!! A little while ago I had 15mm spacers w/ ap2 v1's just on the rear. I loved the stance and it was much more stable. The rear did bite a little better around tight corners. Last week I bought two sets of 15mm spacers and have put them on the front and rear. Looks much more aggressive and handle better
Old Mar 4, 2010 | 01:54 PM
  #56
1nate7's Avatar
17x7.5 +40
17x8.5 +40
You are right with the exception that the front is 7" wide. Personally, I would do the same size spacer all around. A wider wheel with the same offset will sit out further so I wouldn't necessarily have the goal be the same offset front/rear.
marios2000
Apr 17, 2011 09:32 PM
13darkknight
Sep 5, 2010 11:57 AM
jdmjeff
Dec 26, 2008 05:56 PM
Jacksparrow
Nov 8, 2008 06:54 AM
s2kc's
May 7, 2006 04:12 PM
