Spacers on stock wheels
Originally Posted by response,Jun 16 2008, 11:23 PM
j0nathanl3e, what size hub centric rings are you using? Are they Project Kics 67mm bore?
Thanks.
Adam
Thanks.
Adam
15mm spacers will increase track by ~2%. While that should improve cornering capability enough that a consistent driver might see a slight decrease in lap times, it's not anything you'd notice on the street. However, the increased scrub radius is quite noticeable on my car with 45mm offset wheels (equivalent to 10mm spacers).
Personally, I'd rather go with higher offsets and wider wheels/tires than spacers and/or "aggressive offsets" with necessarily narrower tires.
So, stock AP2 wheels are 17x7.0 +55 Front and 17x8.5 +65 Rear. The pictures look like the front may be able to use a 20mm spacer as well as the tire still looks a bit more tucked in compared to the rear. Anybody think this will work? Basically a 17x7.0 +35 in the front and 17x8.5 +45 in the rear on stock 215/245 tires with a lowered stance similiar to j0nathanl3e's car?
Thank you.
Thank you.
Originally Posted by response,Sep 12 2008, 08:22 PM
So, do you think a 20mm would be able to clear the front? Also did you have to roll your rear fenders? I know most people have to roll on 9 +45 but I think 8.5 +45 should barely clear especially with 245.
