Staggared diameter?
Old Aug 23, 2010 | 10:08 PM
yessamgerg's Avatar
Default Staggared diameter?
So i was wondering if how the handling would be affected if i ran 16x7 fronts with a 225 tire and 17x8/9 with a 255 rear tire. the reason being a complete lack of wide tires for the rear in the 16" size. Also im not interested if you think it would look stupid just how it would affect handling. Thanks
Old Aug 23, 2010 | 10:16 PM
Seattle2k's Avatar
it would look dumb.
Old Aug 24, 2010 | 04:17 AM
ZDan's Avatar
I've thought about using the AP1 rears up front and AP2 rears in back for a cheap track wheel setup.
Might look a bit goofy, though, as the front sidewalls will be a lot beefier than the rears (225*.50 = 112.5mm, 255*.40 = 102mm).
Old Aug 24, 2010 | 10:14 AM
Morrisbaddass's Avatar
"poorman's NSX"
Old Aug 24, 2010 | 04:06 PM
myridechanelle's Avatar
i have this setup on nsx wheels. you will understeer a lot and feel a difference in braking. feels like abs kicks in a lot sooner than it should have.
Old Aug 24, 2010 | 04:24 PM
1nate7's Avatar
If you keep the tire diameter the same front to rear (225/50/16, 255/40/17) then you won't have any abs or braking issues. The handling won't be much different than running 225/255 on a regular 17" setup, maybe a little more sidewall flex in the front. Of course, it will look a little funny but you seem to be OK with that.
Zivman
Feb 4, 2016 11:11 AM
superstuddc27
Mar 30, 2014 05:14 AM
Dumas2k
Jan 23, 2011 06:43 AM
cpl_allen
Feb 11, 2010 04:31 PM
nakedmike
May 15, 2006 03:01 PM
