Star Spec tread depth
Old Dec 1, 2010 | 06:37 PM
hariku821's Avatar
Default Star Spec tread depth
When measuring tread depth on star specs is the middle tread what counts? The middle tread seems to wear down faster than the tread beside it so I was wondering if that is what I should be concerned about or if I should only worry about the rest of the tread.
Old Dec 1, 2010 | 07:16 PM
LickyMYwalker's Avatar
i guess it depends what you run camber wise to determine if it wears out in the middle more or inside. I usually measure from the inside of my tire because thats what always wears out first for me.
Old Dec 1, 2010 | 08:07 PM
JDMQuip's Avatar
They have wear bars for a reason on tires.
Old Dec 1, 2010 | 08:12 PM
hariku821's Avatar
yea, I am just above the bars but the center seems extremely low.
I'm on stock alignment.
Old Dec 2, 2010 | 04:18 AM
ZDan's Avatar
What pressures do you run?
My Star Specs always wore pretty evenly.
Old Dec 2, 2010 | 05:47 AM
spa01s2k's Avatar
Sounds like you have your tires overinflated. My friends star specs wore evenly across the tire.
You should always measure all across the all the tread surface. S2000s wear the inner tread a little more then other cars.
Old Dec 3, 2010 | 01:45 PM
takeshi's Avatar
^ This. Tire Rack has info on its site as well:
http://www.tirerack.com/tires/tiretech/tec....jsp?techid=148
jaxx4k
Apr 18, 2006 03:55 AM
chikai
Sep 27, 2005 06:41 AM
LubedKoala
Sep 21, 2005 08:17 PM
WVtwisties
Aug 19, 2005 01:42 PM
oatnet
Feb 25, 2004 10:07 AM
