Whats considered normal wear?
Old Sep 17, 2005 | 05:10 PM
LubedKoala's Avatar
Default Whats considered normal wear?
Considering the stock camber/castor/toe adjustments on our cars, how "abnormal" should the wear on our tires be? As in the difference in tread wear from the inside of the tire to the outside.
Old Sep 19, 2005 | 05:35 AM
Jim@tirerack's Avatar
Former Sponsor
It would be different on every car. What I have seen is around 10 to 18K rear and close to double that for the front.
Old Sep 19, 2005 | 11:13 AM
s2ka's Avatar
Inside to outside should be pretty flat.
Old Sep 20, 2005 | 07:06 AM
bazaar's Avatar
If you get more than 8000 miles on the rears, you are not having any fun in this car.
Old Sep 20, 2005 | 09:12 PM
hirev's Avatar
stock tires went 19k, not completely bald but worn enough that i thought they needed replacement. went with pzero-nero, excellent grip wet and dry and quieter...better wear i will expect...more expensive but worth it.
Old Sep 21, 2005 | 12:34 PM
LubedKoala's Avatar
So the wear should be pretty flat and even? I'm running those yokohama avs es100's on all 4
Old Sep 21, 2005 | 04:23 PM
s2ka's Avatar
Yes, they should wear flat. I had some ES100 tires, not a bad tire for sedans... but you can do a LOT better than that for the S2000.
Old Sep 21, 2005 | 08:17 PM
LubedKoala's Avatar
I was short on cash at the time. Good thing about these tires on the S is that the traction slowly breaks, you can control it alot better when you realize it's about to slide. But yea, there are much better tires out there. Thanks for answering me.
Hobbs5313
Aug 10, 2007 07:26 AM
WVtwisties
Aug 19, 2005 01:42 PM
JPit
Apr 3, 2002 08:52 AM
va_john
Jan 21, 2002 09:33 PM
Gaspasser
Mar 19, 2001 03:36 AM
