Stupidest question ever ... no, seriously
Old Aug 21, 2007 | 03:22 PM
zbrewha863's Avatar
Default Stupidest question ever ... no, seriously
Ok so I contemplated not even asking this question b/c I know I will be ridiculed for it, but I'm in law school so I'm used to it
Here goes ... I am buying a set of wheels, 18x7.5 and 18.8.5, and I had two incredibly retarded questions.
First (actually a two part), will I have to get a yellow box to re-calibrate my speedometer? If there are sizes that will allow me to run w/o a yello box, what are they?
Second, will the 18s raise my ride height? I was told that they would essentially lift my car 1" off the ground (over the stock 16"s), but it seems to me that if I was running the correct-size tires, that would not be an issue?
Thank you for your answers in advance, and please, keep it friendly
Old Aug 21, 2007 | 05:27 PM
negcamber's Avatar
Use the tire size calculator to find tires that give you diameter as close as possible to the oem diameter. You will not need a yellow box nor will the car be higher if you do this.
http://www.miata.net/garage/tirecalc.html
Old Aug 21, 2007 | 07:04 PM
zbrewha863's Avatar
Thank you, according to that calculator if I run 215/40/18 front, 245/35/18 rear my speed will be off by relatively 0.5mph, which is fine with me. Thanks again!
dsthez
Apr 4, 2010 03:40 PM
trymev8
Sep 1, 2009 12:00 PM
nightcrawler7188
Oct 5, 2007 09:00 PM
copmagnet82
Apr 19, 2006 10:15 AM
CyrusA
Feb 29, 2004 05:07 PM
