Are these wheel sizes ok?
Old Mar 3, 2006 | 05:11 AM
wadsy's Avatar
Default Are these wheel sizes ok?
Front 17x7.5 et45 Rear 17x8 et48
If ok, what would be the desired tyre (tire!) size?
Cheers
Old Mar 3, 2006 | 07:05 AM
papa5murf's Avatar
no...
17x7.5 has to at least be a +48 in the front...... the rears will work tho...
Old Mar 3, 2006 | 10:29 AM
spa-zz's Avatar
The fronts will work, but they may rub occasionally. It's not too bad. Some people do run that offset and never have problems. Some do. It depends on how much camber you have and what tire you choose. If you run a 205 tire, you should be OK. If you use a 215, marginal.
dmw16
Aug 28, 2006 07:40 AM
darkfx
Feb 13, 2006 06:34 PM
S2X
Oct 5, 2005 09:05 PM
tunerjetta29
Apr 25, 2005 09:58 AM
04RioS2k
Jan 15, 2005 08:33 PM
