Tire surface
Old Oct 4, 2001 | 05:46 PM
jays2000's Avatar
Default Tire surface
I bought the new tire last two month and this month my urface tire almost gone so any idea why this happen i'm wondering about the tire pressure. I'm i put too much air pressure in the tire I have the 255/35/18 for the rear and put the pressure to 36psi should i put only 32psi to make it better to worn out the tire.
Old Oct 5, 2001 | 08:05 AM
Phantom's Avatar
36 psi is fine...
What do you mean by tire surface...tire tread?
Old Oct 6, 2001 | 09:55 AM
Jim@tirerack's Avatar
Former Sponsor
Even if you have an 18" wheel and tire you would still run your factory recommended air pressures. If the tire is worn out in 2 months you either drove alot of miles or you drove the car extremely hard. Even with too much air pressure the tires should not wear out that fast.
Jim
Old Oct 6, 2001 | 09:32 PM
jays2000's Avatar
do i have to do the alignment of my car to make it not worn out fast.
Old Oct 7, 2001 | 10:04 AM
jschmidt's Avatar
[QUOTE]Originally posted by Jim@tirerack
[B]Even if you have an 18" wheel and tire you would still run your factory recommended air pressures.
Old Oct 10, 2001 | 07:19 AM
Former Sponsor
If you run higher air pressure the tires will wear in the middle and the wheel will be more likely to bend. With more air in the tire the tire will be stiff and the wheel will absorb all the hit.
Jim
Old Oct 10, 2001 | 11:44 AM
CoralDoc's Avatar
Jim - I thought that proper, or even high inflation helps to protect the rim from damage. E.g. the tire will collapse and the rim will take a hit when the tire pressure is low and you hit a pothole. Are you suggesting that high tire pressures transmit more of the force of a hit to the rim in one particular place? I thought that the impact force would be spread around the rim if the tire was properly inflated, or even inflated a little on the high side.
Old Oct 11, 2001 | 10:12 AM
Former Sponsor
I recommended proper inflation but not overinflation. When the tire is overinflated the wheel absorbs the hit and the tire does not deflect the hit.
Jim
Allstar
Oct 14, 2007 03:28 PM
inactiveuser1114
Aug 20, 2007 06:16 AM
jayn
Mar 23, 2004 06:55 PM
Speedracer
Nov 26, 2002 03:47 PM
jays2000
Oct 6, 2001 10:09 AM
