Tires or alignment
I recently had S03s mounted and noticed the difference in handling in the car. Trouble is that I also had the cars' alignment done at the same time. The specs for the alignment were far different than the actual result after the new tires were mounted. Once they aligned the car per the specs I noticed too much sway. The next day I asked them to put the alignment back towards where it was before, but within the specs of the manual. The original alignment was way out of spec.
The car still doesn't handle like it did prior to the new tires and alignment job but I'm not sure what is causing the difference in handling.
My question is: What alignment, front and back, is best for the car?
Wrong question...
The S03's are the problem read this whole tread:
https://www.s2ki.com/forums/showthread.php?...?threadid=32775
Here is the answer to your alignment question
https://www.s2ki.com/forums/showthread.php?...=alignment+tire
