tires rubbing
Old Sep 13, 2006 | 03:29 PM
b16horse's Avatar
Default tires rubbing
Ok my problem is that i have a set of work meister sp1 in 18's on my car with the eibach springs and koni shocks. and i'm getting alot of rubbing on the driver side. The tires are 225/40/18's toyo proxes T1Rs.
One main question is does ANYONE PLEASE know of a solutions for my problem.
The only thing i could come up with is change the springs to a higher set. Does anyone know of springs that drop the car the least other than factory?
Thanks
Old Sep 13, 2006 | 03:44 PM
DerrS2K's Avatar
Run more negative camber up front or swtich to a 215 front tire.
Old Sep 13, 2006 | 04:28 PM
sweetsleeper's Avatar
what offset?
Old Sep 13, 2006 | 05:05 PM
racerfan's Avatar
Depends if you are slammed, on any wheels they will rub basically if your springs are too low and you don't have enough camber and travel room.
Old Sep 14, 2006 | 02:09 AM
b16horse's Avatar
+56 in the front and +62 in the rear
well thats the reason i got the eibach was cause it isnt suppose to slam the car. And for some reason that i dont know why is that the left of my car is lower than the right side. Does anyone know this problem?
Old Sep 14, 2006 | 07:17 AM
TJF's Avatar
TJF
Its lower cause you are sitting on the left side
get an alignment, I imagine dialing in a little more negative camber will cure what ails ya'.
Old Sep 14, 2006 | 11:14 AM
b16horse's Avatar
well obviously when i'm sitting in the car the left side is going to be lower, but i'm saying this when no one is in the car. And adding more negative camber would just kill the tires also by eating away the inside treads.
Old Sep 14, 2006 | 12:07 PM
wanabe's Avatar
agree with the alignment solution...
put 18s on eibachs on mine- rubbed on all 4 corners
let it settle about aweek and had an aggressive street alignment done to the car- no more rubs (except the fronts on good bumps) !
s2k aok
Jul 29, 2008 12:06 AM
amos
Jun 23, 2008 09:28 PM
03S2kStud
Mar 26, 2006 02:51 PM
TrIcKeD_oUt_s2K
Dec 1, 2005 10:35 PM
No Rice
Jul 17, 2002 02:19 PM
