Torques with rolled arches
Old Jul 3, 2014 | 05:27 AM
jimmyvtec's Avatar
Default Torques with rolled arches
First of all hello everybody this is my first post so please be gentle. I have just had my arches rolled in order to accommodate wider wheels. The wheels iam after are Rota Torques (drifts) as I want the concaved look. The size iam looking at is 17x9 et 30 on the front and 17x9.5 et 35 on the rear. My question is wil these fit now my arches have been done, or will I need further mods like spacers etc? Additionally will this noticeably effect the handling in a negative way? And what size tyres would u run with these wheels?
I have read all the fitment guides but cant seem to find info on what will fit after having the arches rolled. I apologise if this has already been covered but would greatly appreciate some help and information.
Cheers Jimmy
Old Jul 3, 2014 | 08:58 AM
Manga_Spawn's Avatar
Site Moderator
No they will not fit. Spacers would be the last thing you need as that will only make things worse. The front needs to be at +40 at least. I run 17x9 +43 on the front with a 245 and I had to pull the fender some and run -2.5 degrees for them to fit. For the rear the 17x9.5 +35 can fit but you will need to run at least -3 if not -3.5 camber to fit them with a 255. You can stretch a 245 and get a little more room but thats as much stretch as I would recommend. I would look for something in the +40 or higher for the front and if available +40 or higher for the rear as well in those specs.
Old Jul 3, 2014 | 09:20 AM
1nate7's Avatar
What suspension are you on? I would not even try this at stock height, wheels that aggressive will look silly.
If you are lowered, it can be done but you will have to compromise with stretched tires and quite a bit of negative camber. I'm not recommending it, but you could run a 215/45 front and 245/40 rear.
Old Jul 3, 2014 | 10:33 PM
jimmyvtec's Avatar
Thanks for the quick replys. Iam going to take your advice and go with the same wheels but in 17x7 and 17x8.5. I did want the concave wheels but its just not worth it by the sounds of it. Iam sure the flat wheels will look ok.
Cheers Jimmy
Old Jul 3, 2014 | 11:57 PM
riceball777's Avatar
Stretch tires and hella flush = the gayness
Old Jul 4, 2014 | 01:20 AM
jimmyvtec's Avatar
" hella flush" WTF is that surposed to mean?
Old Jul 4, 2014 | 01:34 AM
IrishCarBomb's Avatar
It means the wheel is flush with the fender. Hella is just a stupid term created by norcals.
Old Jul 4, 2014 | 07:57 AM
jimmyvtec's Avatar
Right ok thanks for clearing that up. Gay it may be but id rather have wheels that fit right and dont screw up all Hondas good work.
TougeS2k
Apr 22, 2013 09:22 PM
Red2ks2k247
Nov 28, 2012 10:15 AM
XtbateU
Apr 13, 2012 03:50 AM
ronaldng0809
Nov 8, 2007 07:37 AM
myridechanelle
Feb 10, 2007 01:23 PM
