Two different rear wheel sizes on the same car!
Old Mar 25, 2005 | 09:29 AM
El Brujo's Avatar
Default Two different rear wheel sizes on the same car!
I bought a MY03 used last summer that had 17" BBS (LM) rims. Now I need to replace the rear tires and I noticed that there are two different rear rim sizes on the car--both are 17in. diameters but one side is 8 inches wide, the other is 8.5 inches (the fronts are both 7.5 inches). I guess I'll have to replace one of them, but which one?
A related question: I have noticed a vibration in the car above 70mph--kind of pulsating. Could the different rear wheel widths have anything to do with this? Could I have damaged the rear end or something running these wheels? The car has 14K miles on it. Any advice is welcome. Thanks. -El Brujo
Old Mar 25, 2005 | 10:43 AM
The Hoth's Avatar
Different tread width is perfectly fine. Your vibration can be many things(slow leaks, tire balance.....etc). But it is probably not caused by different tread widths.
Old Mar 25, 2005 | 11:27 AM
watermain's Avatar
Just to clarify - the wheel is wider, not the tread width. The contact patch should be very close to identical. You never want to have contact patches that are significantly different on the same axle - that's just asking for trouble.
In this case it may not make much of a difference that the wheel is half an inch wider.
Old Mar 25, 2005 | 11:33 AM
The Hoth's Avatar
Oh...different size on the same axle? Sorry, I misread it.
Of course it is a very bad idea.
Old Mar 25, 2005 | 06:48 PM
SIIK2NR's Avatar
Get it fixed!!!! and go with the 8.5".
Old Mar 25, 2005 | 09:22 PM
SpeedxRacer's Avatar
Having different widths = having different weight on both sides which is bad.
giligoulu
Jul 30, 2009 09:59 AM
ar311unity
Apr 13, 2009 03:11 PM
Ckcrigger
Jan 4, 2005 11:40 AM
simons2k
Sep 1, 2003 04:36 PM
Tedster
Nov 13, 2001 06:57 PM
