VSA LIGHT!
Originally Posted by fastmhz,Jan 27 2008, 01:47 PM
Negative.
They didn't even bother shooting wires or anything! They just assume it was the rims and tires and called it a day. I'm headed to another dealership for sure!
Originally Posted by LagunaS2K,Jan 27 2008, 03:27 PM
...my track set is 215-40-18 and rear is 265-35-18.
i didn't have a single VSA light problem unless i manually pressed the switch...
Originally Posted by Siepel,Jan 27 2008, 05:10 PM
Did you ever run your track set without disabling VSA?
the problem with VSA is it cuts out throttle on the DBW so your not only pulsating the ABS the ECU is also closing the throttle.
It would not be that bad if the VSA does not control the throttle this way you can still stay on the power and let the ABS kick in.
jsenclosure
17
Jan 20, 2011 02:35 PM
