Weird alignment?
I took my car this morn to get aligned and the guy said he couldn't put it to USDM factory spec because I was out of adjustment. He said my suspension must be bent.... but both sides bent almost the exact same???? Anybody heard of this.
I'm running 17x9 rears with +65 and Espelir Springs.
Is it possible that there just is no more adjustment and -1.7 degrees camber is the most towards 0 I can possibly get?
Quoted from Doc (Az)
Ya, I haven't heard anything bad about them, if I hadn't found the Eibach's at a steal price (thnxs Jayhawker!) I probably would have tried them. I think they are supposed to drop even more than mine. You will need an alignment as soon as you put them on, and then again later as they settle. Don't be surprised if the alignment guy can't get them quite to stock specs. Mine feel great, slightly stiffer than stock, but when I corner it is even more like glue on the road. They are a good alternative to coils if you don't plan to track, or are looking for that lowered look until the cash for coils come along.
Quoted from dreamgetter1 (Az)
Ahem, that would be Scott not Rick...I waited for a couple of months before I got my alignment by Jordan's. He couldn't get the rears to stock spec but it was pretty close, the fronts he got to spec.
anarchy187
Dec 2, 2011 02:31 AM
