Weird road hugginess after new wheels/tires.
I traded my oem wheels/tires for a set of SSR GT1s. I kept my rear tires, and the fronts are now toyo tr1s.
I haven't gotten an alignment yet, but will this saturday.
I've noticed on these Toyos that they hug the crevices and cracks in the road alot...i'll be driving along and the steering wheel just gets pulled to one side or another as the car rolls along a crack of bump in the asphalt.
Is this a funciton of more grip in the tire? To low a pressure? Not being aligned? Maybe not having the hubcentric rings? I can't figure it out....the stock fronts didn't do this, and the first time it happened was at 100mph on the fwy and i almost crapped my pants when the car started darting side to side....
thanks..
thanks..
wheels are
Front: 17x7 +45
Rear: 17x8 +45
i'm running 32psi all around now...used to run that on my WRX with mucho success. But i think i'm gonna try 34 front, 30 rear....
thanks.
Front: 17x7 +45
Rear: 17x8 +45
thanks.
Originally Posted by Kwyjibo,Apr 12 2006, 04:42 PM
wheels are
Front: 17x7 +45
Rear: 17x8 +45
thanks.
Front: 17x7 +45
Rear: 17x8 +45
thanks.
ok...did some reaserch on tramlining and looks like i'm just SOL. and have to live with it.
Maybe with an alignment on saturday the problem will lessen, and maybe when these tires wear out some different ones will tramline less...
damn i hate the roads in Los Angeles.....
kwyjibo, you are not alone I just replaced the tires on the S. And my car is doing the same exact thing at the same exact speed. I can describe it as a high speed drift of a sort. It will do it right or left, its like a high speed twitchiness. Let me know if that alignment helps. I had mine aligned but I did so with the new rears being on the car only. Then my fronts came in as they were on back order and I mounted and balanced them and added them to the mix. Anyone know if the alignment needs to be performed again now that all four tires are the same? Because my car is not acting the same. No vibration of any sort just this high speed drifting.
No the fronts are 225/45/17 and rears are 255/40/17. My question is do I have to get it aligned again due to the fact that the 225's were not on the car when I had it aligned a week ago. The stock 215's were.
