What is hubcentric?
Old Apr 15, 2001 | 01:53 PM
nwk00's Avatar
[QUOTE]Originally posted by Prolene
[B]I just measured the rear oem wheel center opening and it seems to be larger than the center ring of the mounting point and the same diameter of the Spoon. If correct, the Honda oem wheels are "lugcentric"!
Old May 7, 2008 | 09:08 PM
GPW-AP1's Avatar
Reviving this from 7 years ago...LOL...Anyone know where I can find some red hub centric rings for the rear mugen mf10's? Will any hub centric rings work? Please advise. Thanks!
Old Jul 28, 2008 | 08:06 AM
moxie50's Avatar
Think you better measure again, I've had Hondas since 1975, all have been hubcentric. Any manufacturer would be hubcentric. Threaded fasteners are for holding things together, and DO NOT LIKE being bent while doing so. If you are supporting the car's weight on the wheel stud you are constantly "working" that metal back and forth. The studs are overengineered so immeadiate or even long term breakage is unlikely, but have you ever bent a piece of metal back and forth until it breaks? Same thing. Its not if, but when. If you see wheels that you think are cool visually, and their manufacturer cares not to spend the money to have the wheels bore fit the car's hub flange, either get the proper (METAL) ring to adapt it to hubentric, or be aware you are comitting an engineering bastardization, however minor it may end up being. Said wheels may look very cool, but I wouldn"t race or track that car.
Old Jul 28, 2008 | 08:35 AM
Jim@tirerack's Avatar
Former Sponsor
The Honda wheels are hubcentric. Like was posted earlier the front and rear hubs are different on the S2K. Lugcentric is never a good idea. You will end up with a vibration in the wheels. There is no way to mount a wheel perfectly on 5 points.
Dredd123
Oct 2, 2012 06:30 AM
chrisaltima
Aug 4, 2010 03:45 PM
RHAP1CD2
Feb 27, 2007 10:35 AM
SolReborn
May 14, 2005 07:14 PM
