What size tires? Emotion 17x9 +44
Im looking into buying some Work Emotion cr's in the 17x9 +44 and 17x8 +47 offsets. What tire size should I go with. Will be lowered on Tein S-Techs and im sure I may have to roll the fender in the rear. Any info would help....Thanks!
245-40 rear and a probably a 215-45 front but you may be able to fit a 225 front. i havent tried a 225 but another member may have so hopefully someone will chime in and let us know if it fits
Originally Posted by silentdancer,Apr 29 2007, 07:29 PM
215/45. 245/40 should be fine, if you are rubbing dial in some negative camber and you will be fine
