whats the correct offset for S2K?
Old Feb 28, 2005 | 08:00 PM
SpoonTypeR's Avatar
Default whats the correct offset for S2K?
i'm thinking of buying work rims
the offset is 17x7 +42 and 17x8+47 is that correct offset for S2K?
and what size of tire should i use for Track and street driving?
215-45-17 front and 245-45-17 or what do u guys suggest?
thanks
what what tires are good?
Old Mar 2, 2005 | 07:26 AM
marc r's Avatar
Honda S2000 Convertable 2 Door 2000-2003
-OEM Wheels
F 16X6.5.....+55mm.....70.7mm hub bore 17.5lbs
R 16X7.5.....+65mm.....64.1mm hub bore 18.6lbs
5-114.3 Bolt Patter 12X1.5 Lug Nut w/19MM Head
WIDTH....................OFFSET ..........................WIDTH OF TIRE
FRONT
7.0........................+40/+45.............................205/215/225
7.5........................+40/+55.............................205/215/225
8.0........................+40/+55.............................205/215/225
REAR ONLY**DIFFERENT HUB BORES FROM FRONT TO REAR***
8.0........................+45/+55.............................245/255
8.5........................+50/+65.............................245/255/265
9.0........................+55/+65.............................255/265
9.5........................+60/+65.............................255/265
10.0......................+73/+75.............................275/285
Comments:
+40MM offset with an 8inch wheel is at the edge of
the fender with the tire a 1/4 inch outside the fender.
LOWERED VEHICLES MUST USE HIGHEST OFFSETS POSSIBLE!
Popular Fitment:
17X7.5 +45MM OFFSET 215/45R17 FRONT
17X8.0 +50MM OFFSET 245/40R17 REAR
There you go
Old Mar 2, 2005 | 10:19 AM
Jim@tirerack's Avatar
Former Sponsor
The tire sizes I would recommend would be either 215/45R17 and 245/40R17 or 205/50R17 and 225/45R17. These should both work but the offsets you mention will be tight.
If I can help let me know.
nemesis2k
Jan 22, 2009 07:36 AM
tallen20
26
May 14, 2008 12:26 PM
lazykiwi
Apr 7, 2006 07:00 PM
RoaringVtec
Jun 7, 2005 02:56 PM
SpoonTypeR
Mar 6, 2005 04:52 PM
