Wheel Fitment Guide
i'm hearing conflicting information regarding the setup below
Front: 17x9 et42 w/BF Goodrich 225/45-17
Rear: 17x10 et50 w/BF Goodrich 255/40-17
some say minor rubbing in the rear once lowered, others say rubbing both front and rear. i'm running stock suspension on an ap2...and will be dropping the car in the winter time.
your help would be greatly appreciated
According to my research (the results of which are in the first post of course) the rear would be OK but the front needs about 10 mm more offset.
Cars vary a bit, so this is a guideline.
When you lower it, if you go back to stock alignment, it could increase rubbing. When you are at the ragged edge of low offsets, you may have to add camber to prevent rubbing. Or, roll fenders.
Cheers,
Ken
Cheers,
Ken
I have the same exact setup except mine are 8 front & 9.5 rear. Trust me they will rub front & back. Not saying you shouldn't run it though.
I have -2 camber front & rear with a 1" drop & they rub front & rear. I'm getting my fenders rolled next weekend & it will take care of it. I like the setup & it will work once my fenders are rolled, but it won't work unless you are willing to run some neg. camber & roll the fenders.
I would suggest running a 8" front & 9-9.5 rear with those tire sizes. My 8 with 225 is barely streched & my 9.5 255 rear is midly streched (mind you i have Falken Azenis 615's that run a bit wide as well. Your 9 & 10 will be quite streched.
Ed
Ed
Hey, the excel spreadsheet link from the first page is broken.
Could someone email it to me??
aidanecaldwell@gmail.com
Thanks!
Thanks!
215f and 245r should fit. But 225 and 255 is really pushing it with those offsets.
Tell your alignment guy to do some reading, cuz he's nuts.
Minimum means minimum offset. Higher numbers move the wheel in, away from the fender lip. The S2000 needs higher offsets than most cars.
Originally Posted by jesusphish,Sep 28 2008, 06:25 PM
I am looking at these wheels.
Kosei K1 TS
17x7
Offset: 50mm Backspacing: 5.98" Bolt Pattern: 5-114
Rec. Tire Size:205/50-17
Weight: 13.7lbs.
Est. Availability: In Stock
Rear Fitment
17x8
Offset: 45mm Backspacing: 6.26" Bolt Pattern: 5-114
Rec. Tire Size:225/45-17
Weight: 15.4lbs.
Tirerack says that these will fit. But I want to put 225 tire on front and a 255 on the rear. I want to put these tires on.
Kuhmo Ecsta MX 225/45
Kuhmo Ecsta MX 255/40
I am a little confused because an alignment guy told me that a +36 offset for the fronts would fit better. This doesn't make any sense to me. Does the "minimum" mean further from centerline or closer? Thanks.
Kosei K1 TS
17x7
Weight: 13.7lbs.
Rear Fitment
17x8
Weight: 15.4lbs.
