Wheel Fitment Guide
Old Nov 2, 2006 | 01:52 PM
  #81
ExoticCarSite's Avatar
I just wanted to make doubly sure my calculations were correct
Old Nov 2, 2006 | 02:26 PM
  #82
slanguage's Avatar
[QUOTE=spa-zz,Nov 2 2006, 04:53 PM] You realize you're posting your question in the very thread that has your answers... right?
Go to the first post in this thread. Your answer is there:
[B]For the front:
6.5
Old Nov 4, 2006 | 02:35 PM
  #83
Aze85's Avatar
[B]For the front:
6.5
Old Nov 4, 2006 | 03:46 PM
  #84
spa-zz's Avatar
Yep, minimum means lowest. Keep in mind that these numbers were taken from data that was based on cars at stock ride height, no fender rolling, and stock alignment. You CAN use lower offsets than these, but you will most likely rub unless you do one or more things to get more clearance.
Old Nov 5, 2006 | 08:43 AM
  #85
Aze85's Avatar
so, if i get a lower offset than that chart says, the wheel will be closer to the inside of the car, right?
Old Nov 5, 2006 | 11:22 AM
  #86
spa-zz's Avatar
No. Other way. Which is why it's hard to find proper wheels for this car.
Old Nov 7, 2006 | 07:41 PM
  #87
Aze85's Avatar
ok... so, lets say the offset is +50 for the front wheels. 17x7.5
since the offset is below all those minimums, i would have to use a tire smaller than listed... right?
Old Nov 8, 2006 | 03:00 AM
  #88
spa-zz's Avatar
Depends on the tire used. Look at the chart again in the first post. You need a certain minimum offset for a certain TIRE width.
If you look at the chart, for a 50 offset for the front, you are between +48 and +53, which would be somewhere between 215 and 225. To be safe, go with 215. If you want to push it a bit, try a 225.
Old Nov 8, 2006 | 06:37 AM
  #89
Aze85's Avatar
ok, thanks alot for the help
Old Nov 25, 2006 | 08:18 AM
  #90
groblaup's Avatar
[QUOTE]
For the front:
6.5
