Wheel Help
Old May 25, 2003 | 01:33 AM
Narcissus's Avatar
Default Wheel Help
Hi guys I am a frist time writer but a long time reader.
I have my 2003 S2000 on order and it will comming soon, Thank God
My question is, will a Racing Hart wheel off a Prelude or Celica fit an S2000?
The bolt pattern will fit but is the offset compatible?
The off set of the Wheel is 43
Will this work?
Can you get spacers if needed?
Thank You for your help
Can't wait to start cruizen with the top down
Narcissus
Old May 25, 2003 | 05:11 AM
turbo_pwr's Avatar
Moved to Tire and Wheel Forum
Old May 25, 2003 | 03:11 PM
Narcissus's Avatar
I have seen from other threads that an 18 by 7.5 wheel is not ideal but can work!
If the offset is 43mm then a 5 to 8mm spacer should be used in the front.
Also tire size?
Say:
Front 215/40/18.... and Rear 235/35/18?????
Please let me know what you guys think.
Thanks for your answers
Old May 25, 2003 | 05:11 PM
1NewLexIS300's Avatar
what size are the rims??
Old May 25, 2003 | 07:02 PM
4IGS2000's Avatar
Spammer
Also tire size?
Say:
when you add spacers you are subtracting offset. hence a 8mm spacer will make a 43 offset into a 35 offset. I would say your wheels will fit as long as the car isnt lowered that much and you dont care about the staggering.
Old May 25, 2003 | 10:21 PM
Narcissus's Avatar
Thank You for answering my question
I will most likely stay away from these rims since I would like to have the car lowered.
Thanks Narcissus
autophiliac
Apr 20, 2006 07:02 PM
Sen
Apr 7, 2004 08:28 AM
sunilr
Sep 18, 2003 09:25 PM
S9Krpm
Jun 11, 2003 07:47 AM
bentrim
Apr 27, 2001 10:49 PM
