wheel setup question
Old May 27, 2011 | 11:52 AM
RedCelica's Avatar
I said nothing about your car....
Old May 29, 2011 | 12:58 AM
Golden Arms's Avatar
You're going to need a lot of camber + stretch tires if you want to run low, but a little pull with probably be recommended.
Old May 29, 2011 | 04:32 AM
matrix_squared's Avatar
not to highjack this thread... but 17x8+45/50 fronts with 215/225 or 17x9+45/50 with 245 be a much better set up??
Old May 29, 2011 | 05:54 AM
ZDan's Avatar
Originally Posted by s200000
really? 10 mm makes that much of a difference and getting some semi stretched tires wouldnt make up for that?
10mm offset change makes 10mm difference.
Think of the difference between a 1mm gap vs. the tire trying to rub 9mm into the fender.
You are going to have less of a problem fitting +45 offset wheels. Personally, I'd want even more offset than that in order to fit wider tires.
Old May 29, 2011 | 02:30 PM
RedCelica's Avatar
depends what you want to do. If you're going to track the car [often] 17x9 +50 255/40/17 all the way around would be preferable. Otherwise, I'd look at a staggered setup, something like
17x8 +45 f 225/45
17x9 +50 r 255/40
Old Jun 3, 2011 | 08:25 PM
brybry562's Avatar
it'll be fine i have 8.5 and 9.5 + 38 with 225 and 245 front and rear not super low but it doesnt rub
Old Jun 4, 2011 | 05:56 AM
slo ap2's Avatar
I'm currently running 17x8,9 +35 on 215/245 star specs. Rolling rears and relocating bumper tabs should be fine for rear, but the fronts are gonna need to be pulled depending how low you are. Also you will need to run camber in the rears. I'm running -2.5 front and -3.5 rear.
Jeaners
Nov 10, 2014 02:01 PM
waldrop405
Oct 24, 2013 05:01 PM
mugginmike
Sep 26, 2013 03:39 AM
lastminute_s2k
Nov 25, 2009 06:24 PM
AJDADDI
May 29, 2006 04:33 PM
