Wheel spacers
Old 07-09-2011, 06:15 PM
EstooK's Avatar
Default Wheel spacers
Ok guy's I am gonna be purchasing some new rubber for the whip, And I am going with 225-40-17 fronts and 255-40-17 rear. The tires are gonna be slapped on some AP2 V2 rims I currently have AP2 V1 on my S stock height no mods (yet). And I was wondering if I would need to get some wheel spacers for the car? I thought you only needed them if you ran aftermarket rims? Well anyone with experience on this situation please chime in thanks!
Old 07-10-2011, 06:22 AM
ryuken's Avatar
There is a ton of info that can be found in this thread
https://www.s2ki.com/s2000/topic/668...p2-oem-wheels/
Old 07-10-2011, 09:40 AM
clarkster009's Avatar
? You never NEED spacers.
Old 07-10-2011, 10:24 AM
1nate7's Avatar
225/45/17 is the correct tire size for the front.
Old 07-10-2011, 11:43 AM
EstooK's Avatar
According to my owner's manual 215/45R 17 87W is the OEM size for AP2 front tires. So I was lead to believe I could use a 225/45/17 which is a bit meatier I guess, And then the discussion about wheel spacers was brought up. To which I thought was rather odd since it's not that much of a difference and the rim is a stock AP2 V2.
Old 07-10-2011, 12:36 PM
Well in your original post you mentioned 225/40/17 which would be wrong. And are you getting confused with hubcentric rings? They are different than wheel spacers. OEM wheels are hubcentric already. AP2 wheels are a plug and play thing.
Old 07-10-2011, 12:44 PM
1nate7's Avatar
Exactly, it's very minor difference and you will have no issues with 225/45 and 255/40. There is no reason to run spacers other than aesthetics unless you needed to clear a big brake kit.
Old 07-10-2011, 01:30 PM
EstooK's Avatar
Originally Posted by EstooK' timestamp='1310327001' post='20764862
[quote name='1nate7' timestamp='1310322260' post='20764761']
[/quote]
Kool thanks for helping me clear that up I can now buy with confidence
Old 07-10-2011, 02:19 PM
jthiles2k's Avatar
Yeah I have AP2V2's on my MY03 S. Running Star Specs
Front - 225/45/17
Rear - 255/40/17
UK Alignment
Lowered on:
- Koni Yellows (Lowest Perch)
- H&R Sport Springs
Absolutely NO rubbing!! I drive very hard in the twisties, so you should be fine
pgss2k
02-27-2016 03:05 PM
jit13
04-10-2011 06:39 PM
darksparkz
06-16-2010 07:36 PM
s2knoob89
02-04-2010 08:40 AM
jdmjeff
12-26-2008 05:56 PM
Quick Reply: Wheel spacers
