Old 04-20-2010, 06:08 AM
synekpol's Avatar
Default Wheels and Tires
Hi,
I need some advice regarding 18' wheel fitment. I want to upgrade to 18 inch rims. The rims I'm considering are the Enkei PF01 18x7.5 with 45mm offset front and 18x9.0 45mm offset back. The other is the Enkei RP03 18x7.5 with 48mm offset front and 18x9.0 with 40mm offset in the back. The tire sizes I'm considering are 225/40 front and 255/35 back. I want to fit these without rolling the fenders. Will these fit? If not, what sizes will? The suspension is stock. It's a 2005 model if that plays a difference.
Thanks In Advance
Old 04-20-2010, 10:02 AM
1nate7's Avatar
+50 or higher would be your best bet if you don't want to roll the fenders. Generally speaking, aggressive wheels don't look very good at stock ride height.
Those PF01's would probably work if you run a 245/35 rear and some negative camber. You might consider the OZ alleggerita from Tirerack, it looks similar and comes in offsets that would be an easy fit.
Old 04-21-2010, 11:45 AM
Former Sponsor
Jim@tirerack's Avatar
I agree. With those widths of the wheels and tires you are going to have issues. If you stay narrower on the rear tire the 18X9 ET45 would be close.
If I can help with the tires let me know.
Sincereone
10-05-2017 08:30 AM
barrett4bama
12-12-2011 03:03 PM
Low_N_Slow
02-21-2007 09:37 PM
JAPCAB
10-23-2005 03:56 AM
BigBodyS2K
04-10-2004 10:33 PM
Quick Reply: Wheels and Tires
