Who changes all 4 tires at the same time?
Old Aug 6, 2006 | 08:59 AM
gtg749m's Avatar
Default Who changes all 4 tires at the same time?
I was reading through the forums that when you replace the tires you change them all at once so handling characteristics are not altered (ex. new tires in rear but old up front)
what do yall do with the tires up front that are not completely worn out yet?
or can you actually get new tires in the back and still use the originals in the front for a while until they are worn and then buy new tires for the front?
Old Aug 6, 2006 | 09:01 AM
Enthralled's Avatar
I just got some new rears last week and i kept the old ones on the front cuz they were in good shape.
Old Aug 6, 2006 | 09:06 AM
PilotKD's Avatar
If you're going with the same tires, I don't see why you couldn't just replace the rears, as long as the fronts had a significant amount of rubber left on them.
I went with a different tire when I replaced mine, so I replaced all 4. It's not good to mix tires.
Old Aug 6, 2006 | 09:07 AM
Vanos954's Avatar
As long as all tires are of equal quality (same kinds preferred) and not too old or worn you can replace just one end at a time based on your needs (usually a couple of sets of rears to every front on these cars).
Old Aug 6, 2006 | 09:12 AM
Stratocaster's Avatar
I only change all 4 if I am changing the types of tires. In other words, if the brand and models are going to be differant, change all 4. If you only need rears then buy a matching set of rears that are the same as the fronts. Normally we go through 2 sets of rears for one set of fronts.
You shoud never replace 2 tires that are differant from the other two. And you should never install 1 tire that is differant from the other either.
Old Aug 6, 2006 | 10:15 AM
SpitfireS's Avatar
with everybody above.
And if the tires are not asymetrical one could move the left front to the right front (and vv) to get the most out of them due to a negative camber setup wear.
Note that I'm talking about getting the tire of the rim and putting it on the other rim so you don't change the direction it turns.
Old Aug 6, 2006 | 10:17 AM
BlackJoker's Avatar
with everyone as well. I changed all four of my tires when my rears were worn down because I hated them (Hankook RS-2s) and went to S02s. I'm much happier with the S02s
Old Aug 6, 2006 | 10:26 AM
rijowysock's Avatar
i change all 4. but thats just cause im stupid.
u only need to change 2 if u have same brand.
never change just 1 tho.
riley
Old Aug 6, 2006 | 10:33 AM
gtg749m's Avatar
i was thinking about tgetting the rs2's. what didnt you like about them. ive heard a lot of good reviews about them.
johnnyzr2
Apr 23, 2018 12:47 PM
03 9g
Apr 21, 2013 07:34 PM
P5744D
Jul 5, 2008 09:43 AM
RUGBY
Feb 28, 2008 06:09 PM
jhp012
Apr 1, 2007 06:26 PM
