Will 18x8.5 +35 fit the fronts?
Old 07-13-2010, 08:48 PM
D-style's Avatar
Default Will 18x8.5 +35 fit the fronts?
Hi, as the title say, will they fit the fronts? I'm eyeing a set of wheels that i really like in this offset...
Thanks guys
Old 07-14-2010, 07:10 AM
Froth.'s Avatar
The question shouldn't be will they fit, it should be how much work Will it take to make them fit? Yes, they will "Fit" but it's going to require camber and a roll/pull of the front fenders and possibly a smaller tire.
For reference, this is a 18x8 +45 with a 225/40/18 and -2 degrees front camber, the car is also about 2.5" lower than stock with fully rolled and slightly pulled front fenders
You're looking at adding around 20-25mm more width to the outside of the rim/tire area depending on tire size and camber, so you be the judge on if you would like the fitment enough to justify the wheels.
-Froth
toolowap1
01-09-2014 01:25 PM
Grillo
09-02-2012 07:38 PM
Flawless_S2K
03-25-2012 02:22 PM
s2kfrog
01-10-2010 12:04 PM
PilotSi
10-11-2007 07:21 AM
Quick Reply: Will 18x8.5 +35 fit the fronts?
