28mm offset F and 71mm offset R for 18x8 and 18x10
Old May 21, 2009 | 10:11 AM
ASpec818's Avatar
Default 28mm offset F and 71mm offset R for 18x8 and 18x10
I'm looking at a set of wheels that are 18x8 +28 and 18x10 +71. I was told that I will not need any fender modifications even when lowered. Anybody have experience or a similar setup can chime in and confirm this?
Old May 21, 2009 | 11:05 AM
s2k dre's Avatar
yes they will fit with a slight roll in the rear. The front will clear without a roll with a 215/45 tire.
Old May 21, 2009 | 12:56 PM
tof's Avatar
tof
Actually you can probably get away with 40 offset in the rear without rolling if you run 225 or 235 series tires. But that limits rim width to 8-8.5" or so. And it will depend some on the tire. Mount it all up and see before you roll the fenders.
Old May 21, 2009 | 12:58 PM
ASpec818's Avatar
oh and i'm also dropped about 1". would running skinnier tires decrease performance? i would rather not lose performance just to get these rims to fit, even though they are some sweet te37's.
Old May 21, 2009 | 01:30 PM
tof's Avatar
tof
Sort of depends. A narrower tire might be less expensive, especially if it is a more popular profile. That might let you move up to a better tire. Tire tread design and compound can make a bigger performance difference than a 10mm of width. Watch your stagger, though, unless you like to hang the rear end out (and are good at it.)
Old May 22, 2009 | 11:44 AM
IvyS2k's Avatar
No you don't need to roll the rear is fine but the front just roll a bit, if you want to slam the car then you need roll the front
Old May 23, 2009 | 04:32 AM
jaeyon00's Avatar
id just roll them to be safe if you plan on running thicker tyres later on. if your lowered, i think you'll find scrubbing when going over bumps (depending on how firm your suspension is)
Old May 23, 2009 | 06:30 AM
3r1k's Avatar
You need to roll the rear for sure...
I couldn't drive properly with 17x8.5 +40 with 235 tyres
Old May 23, 2009 | 04:42 PM
jaeyon00's Avatar
+28 offset up front? thats pretty aggressive
S2KSim
Feb 16, 2009 09:09 AM
Tuanster
Jun 6, 2007 06:18 PM
Taquito
Jan 19, 2007 06:51 PM
Aznous
Aug 23, 2006 01:08 PM
wannabuy
Jan 22, 2006 12:09 PM
