will it rub?
Old Jan 18, 2006 | 11:54 AM
designfreak's Avatar
Default will it rub?
thinking of picking these up, any ideas whether they will rub at all? :
Fronts: 17 x 7 +43 with 215/45/17
Rears: 17 x 8 +42 with 245/45/17
thanks in advance for the help!
Old Jan 18, 2006 | 01:11 PM
xviper's Avatar
Look here to figure it out for yourself.
https://www.s2ki.com/forums/index.ph...&f=56&t=342793
Old Jan 18, 2006 | 02:23 PM
Thanks xviper, I actually read that post a little while ago, and its great. That info is actually what drove my question. The problem is that they take into account the rear 8" wheel mounted with either a 225, or 235 tire. The set Im looking at has 245's mounted on it, and as the offset is very close to the "minimum"reccomended in the post I wasn't sure that the extra tire size would through it out.
I guess a more reasonable question would be: the minimum sizes reccomended for rim size as
7.0" wheel: +42 offset (205 or 215 tires)
8.0" wheel: +40 offset (225 or 235 tires)
how close to rubbing would they be. If I went with a set of that exact spec would I be threading the needle?
Thanks again
Old Jan 18, 2006 | 03:29 PM
xviper's Avatar
First of all, the fronts won't be a problem unless you're lowered a lot.
As for the back, one can take the information we already have access to .............
Commonly, we know that a 17" X 9", 65mm offset rim with a 255 tire rear has no problem on an S2000 unlowered.
So let's look at what you're trying to do:
-reducing the width by 1" is like pulling the rim in by 1/2" (12.7 mm)
-a 42mm offset would bring the rim out by (65 - 42) 23 mm.
So far, you've brought the outer edge of the rim OUT by about 10 mm.
But, you've elected to go with a tire that's 10 mm less than 255, making it come in by 5 mm. Although the rim comes out by 10 mm, the tire (the important part that might rub) will only stick out 5 mm more than the commonly seen set up I stated above. This is not a big problem. You can do it unless your car is dropped over an inch, in which case, you may have to alter the alignment a bit.
Old Jan 18, 2006 | 03:49 PM
wow...great math! Thanks alot X-viper youve been a big help!
cangta
Mar 28, 2012 02:40 PM
MBAS2K
Dec 30, 2010 05:20 AM
MuckaLun
Mar 11, 2007 11:31 PM
Fuelrush
Feb 13, 2007 11:50 PM
bdoob
May 1, 2005 09:27 PM
