Will this rub...
Old Apr 23, 2010 | 04:19 AM
clarkster009's Avatar
Default Will this rub...
Another fitment question...
I have 17 X 9 +45s.
So I see from the wheel fitment guide that a 245 tire will fit on a wheel with +45 offset on stock suspension without rubbing. It is the widest tire for that offset that will fit without rubbing. My question is, if I am running a 255 tire but with UK suspension at -2 degrees of camber in the rear, will I need to roll? I have heard that quote passed around which says "for every degree of camber, you get 10mm more additional clearance" or something like that. I would prefer to not the rears.
Old Apr 23, 2010 | 11:50 AM
Jim@tirerack's Avatar
Former Sponsor
I would say yest they are going to rub without modification. If you go with a 245/40R17 and run more negative camber you may get away without the fender lip roll.
Old Apr 25, 2010 | 03:07 PM
[APtwo]'s Avatar
Is it true about the 1 degree of camber = 10mm clearance? Someone verify this?
Old Apr 25, 2010 | 03:42 PM
ace123's Avatar
Here's a quick number. I took the tire radius and moved it by 1 degree using trig to get a number. Tire radius from the miata.net calculator is about 315mm. That number is halfway between the radius of a 245 40 17 and a 255 40 17 size tire.
Tire radius * sin(1deg) = offset
315mm * (0.0175) = 5.5mm
Since tires are symmetric, that 5.5mm translates to an actual tire width of 11mm. Sounds like the rule of thumb is reasonable.
Voltek
Jan 29, 2015 09:45 PM
maranelloboy05
Jan 4, 2014 04:59 PM
JSR_AP2
Sep 26, 2013 08:39 AM
petegemelli
Jul 17, 2013 11:13 AM
buzz944
Jul 6, 2009 10:33 PM
