Will these TE37's fit?
Old Feb 29, 2016 | 04:52 PM
coop3422's Avatar
Default Will these TE37's fit?
Last year I got a set of AP2V1's for my AP1. I like them- but I need new tires. I was searching local ads, and found my favorite wheels in my favorite color, white TE37's. Made me wonder if they'd fit without fender roll/tab relocation. Here's the specs:
FRONT:
17x7.5 Offset 48
5x114.3
215/40R/17 Dunlop Direzza ZII
REAR:
17x9 Offset 60
5x114.3
255/40R/17 Dunlop Direzza ZII
Will they fit stock suspension on a dd car without rubbing? I know the fonts are slightly off and should be 215/45, but everything else looks good. Offset on the rear seems fine, wasn't sure about the offset of the fonts.
Thanks
Old Feb 29, 2016 | 05:03 PM
riceball777's Avatar
rims will fit perfect. The issue is the diameter of the front tire is too small. You really want a 225/45/17 for the front to match your rear tire.
Old Feb 29, 2016 | 05:37 PM
coop3422's Avatar
Tires would likely be replaced in a summer or two with 215/45 245/40 MPSS.
Would I be able to turn lock to lock without rubbing as well?
Old Mar 5, 2016 | 09:28 AM
coop3422's Avatar
Curious if these Enkei TSP6 would fit without rubbing. I'd like the rear wheel to be wider, but the offsets looks close:
17x7 5x114.3 17x8 +45 offset. Tires up front are 215/45, rears are 255/40.
Old Mar 5, 2016 | 09:30 AM
RedCelica's Avatar
Youll have to roll the rear; also, I wouldn't stuff a 255 tire on an 8" rim. The OP selection is better, but needs a 215/45 tire up front. You may have to bend the fender tabs just a bit.
Old Mar 5, 2016 | 11:40 AM
coop3422's Avatar
I'm looking to get wheels where I don't have to touch the fenders and tabs dso I guess I'll pass. The TE37's are gorgeous but sold already.
Old Mar 5, 2016 | 12:08 PM
Manga_Spawn's Avatar
Site Moderator
You need +50 or higher offset to not roll fenders. Look at the Enkei pfo1.
Old Mar 5, 2016 | 12:21 PM
coop3422's Avatar
A set of those slipped through my fingers last spring. Oh well, my AP2V1's will do for now.
Old Mar 10, 2016 | 05:24 AM
Rx8toS2k's Avatar
I have the TE37s 17 x 7.5 +48 on the front with 225/45 and 17 x 8.5 +50 in rear 255/40 wrapped in Dunlop Direzza ZII. I am on stock height with no fender modification and no rubbing reported.
Honda_4life_
Dec 30, 2013 08:40 PM
niahuynh
Mar 5, 2009 09:57 AM
SimbaDogg
Jun 8, 2005 12:25 PM
S9735
Mar 28, 2005 12:24 AM
Carlson
Feb 22, 2003 10:23 AM
