Will these fit the S2K?
Yes they will fit. I would recommend a 225/45R17 myself. That would keep you in the correct height front and rear.
If you have a lower offset wheel the 215/45R17 would help some.
Let me know if I can help with the tires.
Thank you
Jim 800-428-8355-364
Thank you
as jim said, that rubber setup has a smaller front diameter than rear, which is backwards. you've got a big enough difference there that i would look at smaller rubber on the rear or larger on the front.
