Would these fit ? Or too wide ?
Old Jan 7, 2013 | 11:55 AM
s2000Junky's Avatar
Originally Posted by Jjnormanyale
i am looking into
18 x 9.5 + 25 or +30 265/35 the tyre is achually 270mm wide.
18 x 10 +30 or 35 285/30 the tyre is achually 291mm wide.
i got a js racing types v2 kit with front and rear fenders. I just want to make sure if that setup will fit without any rubbing issues.
Achually I'm not sure if thats going to work
Old Jan 7, 2013 | 12:51 PM
Manga_Spawn's Avatar
Site Moderator
Originally Posted by s2000Junky
Originally Posted by Jjnormanyale' timestamp='1357591782' post='22251519
i am looking into
With wider front and rear fenders maybe. It is still aggressive but depending on how many MM of extra clearance the kit provides it may fit. But at the same time they better be some killer wheels and not cheapo XXR garbage because instead of spending thousands of dollars on body work you could just buy wheels and tires that fit.
Finally I still question the need for running wheels and tires this wide unless your car is making some serious power. You can easily fit a 265 or 275 tire in the rear on a 10 inch wide wheel and if you buy a good tire it will provide more than enough grip.
Old Jan 7, 2013 | 01:45 PM
s2000Junky's Avatar
Originally Posted by Manga_Spawn
Originally Posted by s2000Junky' timestamp='1357592159' post='22251535
[quote name='Jjnormanyale' timestamp='1357591782' post='22251519']
i am looking into
[/quote]
"Achually" I may agree
We need an emoticon that has the hand wizz over the head in missing the joke look lol Oh well
And seems like everyone with average tires says they dont need wider ones with NA power... until they try them. There is a reason why you guys missed the turn on our last spirited drive and got lost
Old Jan 7, 2013 | 03:32 PM
Site Moderator
Lol I "achually" missed it because you aholes blasted ahead and left me behind the 20 mph minivan and I didn't know where you were stopping.
I am sure they feel good on the track or on a drive but can you really say the added weight and friction don't have an effect on normal driving? Also as you stated with an NA car does the average drives really benefit that much from the huge tires? I just kinda like playing devil advocate.
Old Jan 7, 2013 | 11:49 PM
Jjnormanyale's Avatar
js front fender give extra 35mm and rear gives extra 25mm clearance. Also the car is supercharged vortech v2 at 418whp.
tyres wise i was looking at either federal rsr or a048 depending on the cost as a048 are pretty expensive in europe.
Old Jan 8, 2013 | 05:52 AM
i have a seen a photo on this forum where this guy fitted te37 18x9.5 et22 with 255 40 17 all round without any rubbing issue on the same kit as i have got. I know the front wheels will be fine but i am slightly worried about rear wheel as its and the offset also the tyre size. i know 255 which is actually 260 fits fine all round. But i want to go staggered with the tyres mentioned in my earlier post at Front 18 x 9.5j et30-38 265/35 and Rear 18 x 10 et20-35
Old Jan 11, 2014 | 11:47 AM
cheddaboy's Avatar
Originally Posted by ryuken' timestamp='1357364300' post='22246971
Rear 17x11.5 +57 with 295/35 overall diameter = 25.13" with pulled rears
Tire Rack doesn't carry a 285/35/17 but they do have Kumho Ecsta XS in 295/35/17.
Too aggressive an offset. With this 11.5/295 combo, every single mm counts. I'm running it at a +63 with -3 camber and I am literally grazing the tire as it compresses. Now if you can effectively pull the fender the additional 6mm enough to clear under full compression it would technically be feasible. You cant run anymore camber though or you will have inner clearance issues. I had to hammer the inner fender and shock tower a few mm to clear the rim past this and the top of the tire at full compression. No rubbing now, but its super tight. The entire fender well from outside to inside with cut/rolled fenders is only 12.5". You have to add the camber sweep path of the wheel with suspension movement as well so its a tricky fitment. Offset and camber has to be perfect. Plus I just like being the only guy I know of thats been able to pull it off successfully Its a killer f@#king tire on this car!
So technically if you had over fenders and wider front fenders you could run 11.5 +43 in the rear and 20mm lower offset in the front right?
Old Jan 11, 2014 | 01:51 PM
s2000Junky's Avatar
Originally Posted by cheddaboy
Originally Posted by s2000Junky' timestamp='1357370390' post='22247057
[quote name='ryuken' timestamp='1357364300' post='22246971']
[/quote]
With an honest 25mm additional outer clearance with an over fender then yes you would be good to go for rear fitment with that offset/width and 295. and you would be correct that you would need 20mm more inner clearance to fit the inside up front with the same width rim. However I wouldn't choose to do that personally, you would have a much wider total track width (40mm)vs the rear to make it fit (assuming you had front fenders that would even accommodate 45mm over stock) To me is would look weird having the front stick out that much more over the rear, nor would it handle ideally if you care about your cars higher level of performance. Keep that in mind when you are choosing a wide body or over fender addition. If it were me i'd go with a bit of a stagger keeping the outer track width the same or slightly more aggressive in the rear. If you are going with a 25mm rear over fender then I would do a 25mm front fender and then go with a 10.5" +30 with 265/35. I would also go with an 18" vs 17" since the 295/35/17 is currently discontinued and may or may not be back, so you will have more options in 18" in the future. Here is what your fitment looks like/
http://www.willtheyfit.com/index.php...et2=30#content
whew!
Old Jan 11, 2014 | 02:28 PM
cheddaboy's Avatar
Very cool. I have decided to save myself the hassle lol..probably going with a square setup(cheapo tire swapping)and stick with some 17x9.5 +22's on some 255 or 265/40's..but its def something I wouldn't mind seeing done..of course with enough power to back it up.
Thnx for the quick response!
BloodMoonS2k
Apr 7, 2015 08:35 AM
CYKS2000
Apr 27, 2013 10:12 AM
s2k love
Feb 15, 2011 09:36 AM
sick71_s2k
Jul 7, 2010 06:01 PM
zbrewha863
Apr 10, 2009 05:50 PM
