Would these RPF1s fit my CR?
Old 05-19-2010, 04:17 PM
08YellowCR's Avatar
Default Would these RPF1s fit my CR?
The wheels are in satin black i have wanted a pair for my RioYellow CR for a long time. I was told that i would have trouble puting the stock 255 size tires on the rear because its a 17x8 and not a 17x9. Now these wheels are $700 and i think thats a good deal if i can use them with my stock tire size. But if i had to go down to a 245 size tires would that really change much on my CR? I don't track it it's my dd and i am a newbie when it comes to wheels and tires. Here is the size of the wheels so should i buy them or keep waitng for some 17x9s
17x7.5 +47 Front
17x8 +45 Rear
Old 05-19-2010, 04:33 PM
1nate7's Avatar
Get the 9" rear, it looks SO much better. I even regretted getting the 8" +45 for the front because of the convex spokes and switched to 9" all around, concave FTW. That said, I have seen a 255 which is slightly pinched on a 8" wheel without any issues.
Old 05-20-2010, 11:01 AM
Former Sponsor
Jim@tirerack's Avatar
The 255/40R17 is outside of spec from the tire mfg's. I don't think going to the 245/40R17 is going to be a big deal on the CR. They are just 1/3" narrower tires. For daily driving that is not going to matter.
If I can help with the tires let me know.
Old 05-20-2010, 11:20 AM
//steve\\'s Avatar
Why buy a CR if you aren't going to track it at least a little?
Old 05-20-2010, 02:54 PM
08YellowCR's Avatar
Well i planed to track it every now and than. But every time a chance comes up to track it, it seems something comes up. I will get my tries from tire rack if i get these wheels. I got my last pair from tirerack as well
Old 05-21-2010, 06:21 PM
XGhosT's Avatar
I have the rpf1s in 17x9 +45 with 255/40/17s all around on my CR. On the stock CR alignment the front and rear only rubs a little on certain bumps. The best description of these bumps are that they are sort of like being on a roller coaster or an inverted speed bump. Hope this helps.
Old 05-21-2010, 07:59 PM
Alphamale's Avatar
Don't know if this helps but I'm AP2 V2s lowered 1-1.5 with 255s and zero rub. No fender roll or other modification.
I'd go 17x9 all around though...
Old 05-22-2010, 09:00 PM
mister x's Avatar
One more no vote on 8" wide in the rear. Why go backwards from OEM?
etang789
09-01-2019 07:14 AM
dbwy111
01-21-2016 09:41 AM
End005
03-04-2014 10:44 AM
leester01
Socal Swap Meet
08-01-2012 08:56 AM
hajohehe
04-02-2009 05:55 AM
Quick Reply: Would these RPF1s fit my CR?
