Lightweight 16" wheels and tire sizes
Old 08-06-2011, 02:42 PM
tmek's Avatar
Default Lightweight 16" wheels and tire sizes
I searched for a thread dedicated to 16" wheels and was only able to find one brief thread on 16" wheels with fat tires. If I wanted to stick with 16" rims:
1) What wheel options are people running? What offsets? Pictures?
2) Are you running a 245/45/60 to maintain overall diameter similar to the 245/40/17 on AP2's in the rear? Fronts 215/50/16?
Old 08-06-2011, 07:13 PM
wisdom's Avatar
Click my signature.
I would say that my wheels are fairly light.
Old 08-07-2011, 02:10 AM
ZDan's Avatar
Unfortunately no one really makes "fat" tires for 16" wheels anymore. Unless you go to inferior tires, 225/50-16 is about as fat as it gets for street tires, 245/45-16 for R-comps.
I'm running 16x7 and 16x8 +45 offset SSR Integral A2's, with 205/55-16, 225/50-16 tires (oem sizes).
The few 245/45-16 street tires available are going to be subpar relative to the best tires available, for any performance category.
225/50-16 are already similar diameter to 245/40-17 anyway (~.2" taller, vs. 245/45-16 being ~.1" shorter). They kept tire diameter roughly the same when they went from 16s on the AP1 to 17s on the AP2.
There's going to be a vanishingly small selection of fronts in 215/50-16, too.
OEM sizes: 205/55-16 fronts and 225/50-16 rears is pretty much it for street tires, unless you want to run 225/50-16 all around.
Old 08-07-2011, 06:27 AM
tmek's Avatar
Thanks for the information. Based on availability of tire sizes it appears going to 17" wheels might actually work out cheaper in the long run due to many options in tires.
Old 08-07-2011, 06:51 AM
ZDan's Avatar
There are plenty of options for 16" tires in OEM sizes, typically quite a bit cheaper than 17" tires.
You would have more (and wider) size options in 17".
DanTheManUK
07-22-2008 12:34 PM
pho-shizzle
12-03-2007 05:59 AM
dmw16
07-29-2006 02:17 PM
Sfkn2
04-03-2006 01:38 AM
Sparky
09-23-2001 04:27 AM
Quick Reply: Lightweight 16" wheels and tire sizes
