non stagger 18x8.5 tire question
hi guys,
i.was wondering if it was possible to run 18x8.5 with 45 mm offset all around but use 225 width in the front and 245 width in the rear. reason i would do this is because i already have the wheels from a while back and would like to out them to good use. would anything rub with stock alignment?
hi guys,
you mean 245 in the front? wouldn't the 245 rub? I've heard that running non stagger setup on the s2k throws the balance out of whack and you get really tail happy. since stock runs 225 in the fronts and 245 in the rear there's a gap that i'd like to maintain to keep the understeer and oversteer in check.
oh i was wrong about that. but the ap1 has narrower wheel sizes than the ap2 though i know. i just realized that the hub bore won't fit so i'm going to have to scratch this idea
Ap1 wheel sizing is so outdated I find it rather irrelevant to base off, when S2000 made the update to something more reasonable in 04 for basically the same chassis. But 00-03 are 16" With 6.5" front 205, Rear 7.5" 225.
