square tire with stagger wheels?
Old 10-20-2017, 07:40 AM
Arthas's Avatar
Question square tire with stagger wheels?
As the title says , I have 17x9 +45 & 17x10 +38 wheels with a 235/255 tires. would it be a problem if I switched to a square tire set up (255's) all around, even though my car has a staggered set up on wheels? The wheels are rpf1's, just curious to see if maybe I should just buy a pair for 17x10 to throw in the front if I should not run square tires on my current wheel's.
Old 10-20-2017, 07:47 AM
Midnightdennis's Avatar
255s would be the ideal size for a 10" wheel. Consider a square 10" wheel setup if you want to run a square 255 setup.
Old 10-23-2017, 12:25 PM
Former Sponsor
distinguishedmotorsports's Avatar
i'd still stagger the tires because you likely are not throwing the 10s on the front to rotate anyways. 245/255
Old 10-23-2017, 02:34 PM
1nate7's Avatar
+1, currently running a 245/255 stagger myself.
Keep in mind there is a huge difference in fitment between 9" +45 and a 10" +38, especially when factoring in wider tire (255) as well. Probably not going to happen even with pulled front fenders.
Old 11-01-2017, 03:52 PM
Former Sponsor
Jim@tirerack's Avatar
You can but what are you looking to accomplish? I do it for winter and run the narrower front tires all the way around for more winter grip.
s2Y00
05-03-2017 10:42 PM
jhonnyboy
04-20-2014 06:04 PM
w35t_ap1
03-20-2014 10:25 AM
AFs2k
05-13-2011 02:55 PM
INFMS
20
03-29-2005 10:37 PM
Quick Reply: square tire with stagger wheels?
