Widebody setup
Widebody setup
I just got some 18 x 12 -5 offset basically what would be a good tire size with no stretch and do you think circuit garage fenders would work with these wheels ?
short answer is no. I still think you at its limit you need to be +10-+20 I think. I’m sure the experts in this area will have a more precise answer on offset.
305 or 315 and no, they would sit like 80-90mm outside stock fenders
20-25mm too aggressive for 75mm/cg fenders. You need to be +15-20 with a 12" wheel. m&m is supposed to be 100mm over stock so that would work.
315 on a 11.5" wide wheels sits pretty square. on a 12" there will be a slight stretch but its a great/ideal combination. Up to a 12.5" is spec range for a 315.
so with these flares i would still be poking out rim with flares on and i will be on air suspension
im just trying to see how they would sit with these flares i didnt want to go with m&m but if i have to i dont mine
Yep, poking out about an inch. It would look like a Mexican swap buggy. You need +100mm over fenders minimum on this car in the rear to cover 12" -5.
General Swifty Cactus
04-02-2011 11:42 PM
