Work Emotion CR Kai S2000 Fitment
Old 04-06-2008, 05:10 AM
beesting's Avatar
Default Work Emotion CR Kai S2000 Fitment
Hi
Can someone please advise on the safest S2000 fitment for the Work Emotion CR Kai wheels without having to pull or roll fenders or change the camber setup.
I want to run with 18 x 7.5" front (225 tires) and 18 x 8.5" rear (245 tires).
All the websites I have seen show a maximum of 48mm offset for the 7.5" and 43mm offset for the 8.5". The wheel fitment guide suggests a +53mm front and +45mm rear off set minimum for these wheel sizes.
Just wanted to check to see if higher offsets are available as alot of people seem to be running with these wheels.
Thanks
Old 04-06-2008, 05:59 AM
daktruckie99's Avatar
Are you lowered? I am at stock height and have been riding on a 17x8 +45 in my rear without any issues. Your setup would be similar if you stay at stock height.
If you are lowered, then you'd probably need to do minor work to get them to fit without rubbing issues.
Old 04-06-2008, 08:12 PM
beesting's Avatar
Thanks for the fast response
I am not lowered yet, but want to lower if possible (after the wheels are fitted). Having siad this, I won't lower if i have to modify the fenders.
Would love to speak to someone who has the 18" wheels fitted to find out exactly what offests they went for.
Old 04-21-2008, 09:14 PM
loft8's Avatar
how about CR Kais 17x7 and 17x8 47offset for the rear along with Espelier springs? should i be worried about rubbing?
i haven't purchased the springs yet but would like to if no rubbing issue.
thanks in advance!
floor_filler
02-24-2012 07:20 AM
NGR
05-01-2010 08:47 AM
lzybum
06-18-2009 05:18 PM
Nagata-San74
12-09-2008 04:13 PM
ncspyder
04-18-2005 03:54 PM
Quick Reply: Work Emotion CR Kai S2000 Fitment
