Sponsored by:
Sponsored by: Sake Bomb
Extended Stud Install DIY - Front
Old 04-13-2014, 07:15 AM
rockstar143's Avatar
Default Extended Stud Install DIY - Front
So, my new wheels don't have the openings in the rear face to accommodate the oem stud heads when you use a version 2 spacers, so pretty much limited me to a 20MM being the smallest spacer I could run. I decided that OEM or aftermarket wheels, I'd never again run less than 10MM up front so bit the bullet on a set of Ichiba version one spacers with longer studs.
Now, I know I'll get flamed for it, but I still wanted to share with the community because I couldn't find any DIY threads on it with pictures. I know the right way to do it is pull and have bearing pressed etc, but I had gone this route on my Acura TL with great success. I do not track the car, but I do not feel unsafe with a small portion of the stud head shaved as I've been driving like that for years on a car that I drive spiritedly that weights a half ton more.
Also, the follow up is I hit the shaved area with some flameproof paint to keep it from rusting after.
Start by removing wheel, caliper, rotor. I'd done this recently to paint the hub so it was a breeze to come off.
Here is where you'll need a combination of dremel and angle grinder to take out a chunk of the heat shield, as well as lightly shave the knuckle assembly housing slightly...on the TL, this was all I needed and I was able to hammer out (damaging) the old stud, shaving the new one and carefully putting it back into place. With the S2000 I highly suggest you buy a 12 x 1.5MM rethreading nut (good to have anyway) because I DID slightly damage every single extended stud on the way back in. I used the rethreading nut to fix the threads along with to pull them into place. Keep the threading lubricated as you do that.
Channel created
Size difference
With an old lugnut you don't care about, carefully pound out the old stud (don't hit the hub, it'll suck to have to reshape it)...then use a punch with a smaller hammer to lightly push it all the way through...I use that same hammer from behind to gently knock the new stud in.
Shave down the new nut
and voila...with help from the rethreading nut and my 650 ft/lb impact gun...
I hope that makes sense...I do have all the tools necessary and if I missed a step or something doesn't make sense...please feel free to PM me for more information.
just a typical Friday night, right?
Again, I realize this is uncouth approach to this, but it worked for me. I contemplated not sharing, but oh well, I'll put my thick skin on.
Old 04-13-2014, 01:58 PM
bendang2005's Avatar
Makes sense. Thanks for sharing! No pictures with wheels on?
Old 04-14-2014, 03:39 AM
Yes sir, I've got to edit the pictures. Thanks for the comment.
Old 04-14-2014, 07:00 AM
Also, if you're gonna damage the original removing it, another option would be to cut the stud short and knock it out. May save headache cutting an ear off the head.
Save Ferris (06-01-2019)
Old 04-14-2014, 07:37 AM
^^^Very true,
I guess in hindsight, I probably could have tried to salvage the oem ones...but I figured if I ever wanted to put that length back in, I'd probably just opt for a new set of them.
Old 04-19-2014, 03:34 AM
cheddaboy's Avatar
Thanks for the detailed description. I had 2 studs snap on both front wheels each 3 weeks ago so I was thinking of doing this but ended up just buying some knuckles. Wish I had seen this before though.
Old 04-21-2014, 03:30 AM
You're welcome, man. Thanks for the post!
I will admit, it wasn't the easiest install, took a bit more fenagling than my TL did...but it was worth it.
Old 04-21-2014, 04:23 AM
sdosmil77's Avatar
i know how u feel. i had 2 oem studs break on my left side rear so instead of new oems i opted for arp extended and new bearings. pain but i hope not to ever do again cause of the arp studs. now i just hope the fronts hold off or ill be doing that also but ill take it apart because its not bad thing to put new bearings even your idea is pretty clever
Old 04-21-2014, 04:38 AM
No doubt, man...TBH, it's not even a matter of down time, it's just hating to have to outsource labor. If I can figure out a way to NOT have to go somewhere with a press, I'd rather. Although there are a few shops VERY near home that would likely charge me minimally if I were to remove the knuckles and have them press for me. We'll see. I'm happy with the extended studs although it's definitely a commitment as they are too long to run with closed ended lugnuts without the spacer.
7rrivera7
11-15-2014 05:10 AM
zeroptzero
05-29-2014 03:46 AM
supersteezy
06-08-2013 01:00 PM
sliqq
Southern Ontario For Sale
10-16-2012 01:06 PM
aznhomie
09-26-2004 03:24 PM
Quick Reply: Extended Stud Install DIY - Front
